hello,
I have an ogm and srt (subtitle) file.
What is the easist way to view the movie *with* the subtitles?
The ogm plays by itself in mplayer or vlc, but I cannot get either to recognise the subtitle file. I have made sure they both have the same name, and in the same directory.
Any ideas?
avex.
Hi,
After checking some forums it seems that mplayer has great support for subtitles, but the GUI isnt finished for ogm files.
For normal avi files you can do apple+i, and select a subitle file, but this option is not available for ogm.
Although the GUI doesnt support ogm/subtitles, the command line does!
From the terminal I just had to run "mplayer filename.ogm". The subtitles were the same name as the ogm file, and it started playing with the subtitles.
Glad I found this. I was about to try to convert to divx or do some crazy other hacks >>> like playing the files on a PC! (phew... glad i didnt have to do that).
yoyogi.
Audacity Mac 1.3 Beta - solved my problem but how?
By Rhymester in forum AudioReplies: 5Last Post: 27th Oct 2011, 09:43 -
Formate/specs for video file which play smoothly Across G4 MAC/ PC /MAC PRO
By krijes in forum EditingReplies: 1Last Post: 2nd Apr 2010, 06:18 -
How to convert .SSA to .SRT for with a Mac
By VidHunter in forum MacReplies: 8Last Post: 27th Apr 2008, 15:34 -
Anybody know of an .ogm to .avi converter for Mac?
By LoafingOaf in forum ffmpegX general discussionReplies: 3Last Post: 28th Oct 2007, 02:00 -
OGM players for Mac
By ker-plop in forum MacReplies: 3Last Post: 28th Aug 2007, 13:24
