Hi, I want to convert a Divx too mpg using Tmpenc it is 91.58 min & I want to fit it on a 80 min disc If I change the bitrate down to 950 Tmpenc says it will fit. this seems too easy! will this work. Not sure what info you need to help me so I'll put everthing 640*272 24fps Divxmpeg4 v3 Size 716.110kb length 91.58 codec Div3. This is all mumbo jumbo to me but I hope it means somthing to you.Thanks
Yup, that's all there is to it. I hope you're creating a VCD b/c SVCD would be lousy at that bitrate. If you want to shoot for better quality, then try 2-pass VBR encoding instead of CBR. Minimum bitrate of 250, maximum 1150 and 950 average would create the same size file (1 disk) but would give a higher bitrate where it's needed. It can take twice as long to encode, however.Originally Posted by Kathy"Art is making something out of nothing and selling it." - Frank Zappa
Buy the time you reencode that divx crap into mpeg1 for xVCD it will look extremely pixilated at a bitrate of 950. Yes it will work but are the results worth it?
https://www.videohelp.com/calc.htm
The video you have is highly compressed. Just watch it and be happy it was free. Go buy / rent the movie and do it properly. -
Thanks 4 the quick reply Zippy will give it a go. Yes it is a vcd i am doing will the quality be greatly reduced the file is exc qual.
Holistic,
Gasp!!! Rent[/i]? Watch out, someone's gonna get you.
Actually, if the content IS any good, why not split to 2 CDs? Not a biggie to change disks at 45 minutes. Go potty, get a beer, a snack,whatever.
There IS such a thing as too much compression.
Cheers,
George -
Well, VCD isn't very good quality. If you do SVCD on two disks and you use 2-pass VBR the quality will be much better, more like your source. You'll have to see for yourself what is acceptable esp. with regards to bitrate settings, although that can vary depending on the amount of action in the movie.Originally Posted by Kathy"Art is making something out of nothing and selling it." - Frank Zappa
Bitrate Question
By x0pht in forum Video ConversionReplies: 5Last Post: 17th Jan 2011, 23:00 -
Bitrate question
By SuxRight in forum Newbie / General discussionsReplies: 3Last Post: 3rd Dec 2010, 00:45 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Bitrate question
By eclipse95 in forum Video ConversionReplies: 7Last Post: 10th Nov 2009, 22:03
