I heard about this media player for the ps2 on this board ( http://www.ebgames.com/ebx/product/238164.asp ) and was wondering if you could answer a question, it looks like it plays all divx and xvid files but i was wondering if this is only streamed through the computer or if i can but a data disc (on cd-r) in the ps2 and it will play with this software.
Thanks for the help
?Originally Posted by WhiteKnight54
I dont really understand your question but I'll try to answer.
If it plays on your computer it will play on your ps2 you need a network adaptor and other stuff the ps2 its just a go between for your computer and TV. Sticking VCDs or divx disks in the ps2 wont work with this but it will play the mpeg1,mpeg2,avi,mov.......divx files on your computer and show them on the TV (or you can run the disk on your computer if its not a file that is on your computer.)
https://www.videohelp.com/forum/viewtopic.php?t=185307
There is a Divx mediaplayer CD for the PS2 that will allow you to do something similar, but you need a bootdisk or modchip to make it work.
VCD CD-r's cant be played on a ps2 but DIVX/XVID CD-R's can
Media Player Question
By gazbag in forum Media Center PC / MediaCentersReplies: 1Last Post: 5th Jan 2011, 10:54 -
question re wd hd media player
By julie_152 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Sep 2009, 12:46 -
vlc media player question
By Adventure Man in forum Newbie / General discussionsReplies: 2Last Post: 13th Jan 2009, 18:20 -
Question about Media Player Classic
By Seeker47 in forum Software PlayingReplies: 4Last Post: 4th Aug 2008, 00:58 -
VLC Media player question
By 2Air in forum Newbie / General discussionsReplies: 3Last Post: 29th Jun 2007, 22:50
