  1. I need guys. I am looking for an AIM logger and I dont want to use Deadaim becuase they can easily delete the convos. And I don't want a keylogger becuase it doesnt record both side of the convo.
    Any suggestions anyone to find a program like this?
  2. Member The village idiot's Avatar
    Apr 2002
    Adrift among the STUPID
    Sounds like you got a problem. I can't point to specific things, but you might want to search for something that will log the screen everytime it updates. Then you can see everything, not just the text. There are many, and I'm sure there are a couple of free ones out there.
    There is one other thing you can do... If you are using DSL or cable modem, and connect to it through ethernet, go find a really cheap hub, put it in the sytem so that the modem connects to the hub, and any other computers connect to the hub. There should be very little performance loss. Then get and old junker computer, and install an OS, also install a port logger like GreedyDog (freeware just google it), this will let you log EVERYTHING that happens on the ethnet going through the hub. So you will get all online activity. As long as it isn't a secure website, everything is in plain text, with urls and all. This would be the best way, if you can set it up without other people noticing or asking about it. Some port loggers will even reconstruct the web pages that are logged by the software.
    Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
