I took some DV footage while on a trip last weekend, but due to my wild panning and zoom methods I need to slow the film down a bit. Are there programs that can do this? I'm hoping to improve my filming in the near future so a freeware or trial will be suitable. Thanks.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
virtual dub , premiere , vegas , others
Thanks, I use virtual dub but have never seen anything about slow motion. Can you be more specific? Maybe they are using a term I am not familiar with.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
you can decimate frames or change the frame rate -- that is one (2) ways of slow motion ... a better way is to undersample the frames (vegas can do this very well, so can adobe express ) for smoother motion (re-creates new frames) , there are also some very expensive products that can do very precise slow motion .... they have to interpolate new frames also ...
I know Video Studio 7 has slow motion. And using AviSynth through Virtual Dub can also use slow motion. Guide.
Hello. -
Thanks guys, it didn't look good trying to slow it down, so I changed the audio to 'the William Tell Overture" Now it looks as if it's meant to be like that.
Sony Z5 slow motion
By savadepa in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 27th Apr 2011, 08:09 -
How to make slow motion???
By X_Splinter in forum EditingReplies: 7Last Post: 8th May 2008, 16:01 -
Slow motion
By Pliny in forum MacReplies: 7Last Post: 7th Aug 2007, 00:02 -
Which casmeras are best for slow motion?
By Deathwish in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 2nd Aug 2007, 23:04 -
Slow Motion
By sbuckmybballs in forum Newbie / General discussionsReplies: 6Last Post: 21st May 2007, 02:16
