I have tryed to OPEN a VIDEO_TS folder but nothing happened . Why ?
Results 1 to 21 of 21
AlviseGuest
AlviseGuest
But when i try to load a single VOB file it works . What means ?
AlviseGuest
I have panther , and i retry to install the FFmpegX looking the install help on the site . But nothing , when i try to load a VIDEO_TS directory nothing happen , FFmpegX only works when i load a single vob file.
AlviseGuest
In my Desktop folder
AlviseGuest
Seams that ffmpeg not checks the files and doesn't found a film in the directory : When i load VIDEO_TS and no informations are given , i try to "encode" and the error is this :
100% of encoding in 1 sec
ERROR :
File not found: 'frameno.avi'
Failed to open frameno.avi
-dvd N is deprecated, use dvd://N instead.
Exiting... (error parsing cmdline)
AlviseGuest
I think i installed the correct binaries , may you write here the links to the correct binaries please ?
plgGuest
I am having the same problem. Installed most recent binaries, using 10.3, when selecting a VIDEO_TS folder, no information appears. When hit 'encode', it finishes in about 1 second flat and there is no file. What gives?
SolitudGuest
same problem under 10.2.6.
i have deleted every file except the .vob files in the video_ts folder. may be this is the problem?
There are no "most recent binaries". There are only "working binaries" and "not working binaries".
The working binaries are ONLY the following ones, as indicated on the installer window:
http://prdownloads.sf.net/mplayerosx/ffmpegxbinaries.sit
Guest
link doesnt work for me.
Guest
i had this same problem, and it worked fine after i did a reinstall and ran the installer again. make sure you run the installer.
Guest
I'm getting the same issues as others here. No matter what I do ffmpegX will no load the media out of the VIDEO_TS directory. I have done a reinstall, and I have the "WORKING" files installed. I followed your guide to a T and it's flat out not doing the job. I'm running 10.3.1. Anyone have a solution?
Major is right you are using the wrong bineries. I used to have the same problem until I discovered that there are different versions of the mencoder and mplayer bineries around (by the way, non of them has a version number). The so called "latest" do not work for ffmpegx.
Got to http://sourceforge.net/project/showfiles.php?group_id=62947 and download the "ffmpegX_recommended_bins".
After doing this everything worked as described on the ffmpegx homepage.
Good luck!
karipuGuest
There is three diiferent kinf of binaries:
binarieswithoutdvd.sit
ffmpegxbinaries.sit
stablebinaries.sit
Do I need toinstall all od these or just one of them, if so, whicj is the right one?
karipuGuest
There is a three different kind of binaries:
ffmpegxbinaries.sit
stablebinaries.sit
Do I need to install all of these or just one of them, if so, which is the right one?
(and what is the differencies between these binaries?)
The right one is ffmpegxbinaries.sit. The difference is that all others don't work. For detailed installation instructions, check this page.
An idiot and a video_ts folder...
By CitizenErased in forum Newbie / General discussionsReplies: 11Last Post: 24th Jan 2011, 17:00 -
.vob to mpg no video_ts folder
By klein in forum Authoring (DVD)Replies: 8Last Post: 25th Jan 2009, 19:01 -
Another folder than Video_ts and Audio_ts
By claudiofran in forum Authoring (DVD)Replies: 12Last Post: 3rd Mar 2008, 14:39 -
removing CSS from a video_ts folder?
By ehmjay in forum MacReplies: 23Last Post: 29th Feb 2008, 21:15 -
No Video_TS Folder..
By NatalieR in forum ffmpegX general discussionReplies: 1Last Post: 5th Feb 2008, 11:53
