  1. Weird problem ive downloaded a avi file. while the quality of the video is great it sounds as if the batterys are running out on the video player.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    it may be your system -- look in properties and see what frame rate it is playing at vs. what it is supposed to be playing at ..
  3. frame rate 23f/s
    data rate 190
  4. i think this might be an audio problem, i tryed to rip the audi out if it and the reported error was something about audio codex. Before you say, yes i have gspot and checked it reports that i have the right codex for both video and audio
  5. Banned
    Oct 2003
    Americas
    I recall having similar proble when I edited video in Premiere and forced non standard audio (different sample rate). Ended up with slow audio. Maybe that's the case. Check properties if typical sampling was used.
    If the file is of some valu, u may reedit audio only but prolly u will get not the full length (not matching video length).
