    Dec 2002
    Atlanta, Georgia
    Well, just recently ive been getting this error, and its been happening to ever dvd that i put in.
    Heres an image of the:
    im nt sure what is causeing this, and a lot of weird stuff has been going on with my comp. But if i press the abort button it will go and load the dvd and be ready to decrypt. But i tried that and it when theough its whole thing and when i went to the hd where i put it, the files were not there, the space on the hd decreased about the proper amount, but it there were no files
  2. what changed to your system did you make (hardware, software) prior to getting the error message? maybe reinstall Decrypter will help.
    Dec 2002
    Atlanta, Georgia
    it should work now, i had to upload it to my site since i couldnt figure out how to attach it
  4. try playing the dvd while ripping it.
    Dec 2002
    Atlanta, Georgia
    so use a program like powerdvd and rip at the same time?
    wouldnt that cause even more problems, i dont really have a fast comp, i think it would lag to much
  6. correct.
    i have a P3-933 and have no problem. your cpu is faster than mine but then you have win98 and i run 2k. you will have system resource issues but it may still work. give it a go.
    also try ripping with your burner and see if you have the same problem.
  7. just re-read the final part of your post...do a search of your HDD(s) to locate the files Decrypter supposily ripped. if your drive space is reduced by the amount of the contents of the rip they are somewhere.
  8. I have a (2yr old) Sony DVD Rom drive which is hopeless with ripping, it will succesfully rip only about 1 in every 3 discs I try, my Pioneer 106 DVD-R drive rips everything perfectly. It could just be your drive?? I have found some DVDrom drives are funny like that!
