Results 1 to 10 of 10
    Oct 2003
    Winter Springs, FL
    what is the best and fastest program to convert avi to vcd? i want something that doesn't take 15 to 20 hours to convert. please help thanks.
    Oct 2003
    Winter Springs, FL
    that is the program i use that takes so long isn't there a faster converter than that?
  3. Member rhegedus's Avatar
    on the jazz
    Yes, for an awful lot more $.
    The guides to the left will provide you with the answers.
    Regards,
    Rob
  4. There's AVi2VCD look in the tool's link on this site also www.doom9.org for free software
    Oct 2003
    Winter Springs, FL
    i already have avi2vcd and that is slower than tmpgenc. isn't there any more suggestions out there
  6. Member rhegedus's Avatar
    on the jazz
    With a 400MHz Celeron, everything will take a long time........
    Regards,
    Rob
  7. "rhegedus" is right your PC is to slow. I have two PC's a P2 400 and I used ro encode to VCD a two hour movie took me about 24 hour's with TMPG on my AMD 1.8XP the same two hour movie now take's 2 and a half hour's to encode.
    Dec 2002
    Like I said before, I can make an xVCD in under 1/2 hour, and that's from a DVD. Anything over 2 hours and it's your CPU. Re-read the part about Celeron 400's with no cache (your better off with anything, litterally anthing else faster than a 266 Mhz).
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  9. Member rhegedus's Avatar
    on the jazz
    Wow!
    How come it takes me about 1.3x real-time to convert DVD to VCD (DVD2AVI then TMPGEnc) ?
    Regards,
    Rob
