Vdub is dropping lots of frames when i'm capturing this specific movie from vcr. It's a brand new tape, and vdub is dropping frames always at the same point. I've tried with another copy of the movie, and it's still dropping. Other movies capture ok (30fps @ 640x480). I think it could be some kind of scrambling, or lock. Is it possible?
<font size=-1>[ This Message was edited by: dabliu on 2001-10-09 22:08:45 ]</font>
i have the same problem when capturing at a higher resolution. I tried 352x240 and drops fewer frames which you wouldn't notice when played back on a standalone player.
That seems to happen if there's alot of noise or motion at a particular point, try capturng at 352x480 (to get all the scan lines) and resize appropriately (horizonatal resolution isn't as important as vertical), also try capping the audio seperately then mixing it back in (as a last resort
Dropping frames on New PC
By beammeup in forum Capturing and VCRReplies: 9Last Post: 16th Apr 2012, 12:36 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 22:15 -
HDVSplit dropping frames
By Boadicea7 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2009, 09:47 -
Dropping frames while converting to .dv
By Huntr777 in forum MacReplies: 1Last Post: 10th Jun 2009, 17:19 -
Hauppage WinTV, BTWinCap to Vdub, dropping frames
By elvisish in forum Capturing and VCRReplies: 0Last Post: 4th Aug 2008, 12:03
