  1. Is it possible and how capture a tittle from a DVD another tittle from another DVD and make a new DVD with a menu to play the title you want.
  2. tools: DVD Decrypter, TMPEGEnc Author, DVD Shrink
    i assume you have used these tools before.
    1. rip both DVDs in File Mode to separate folder on your HDD.
    2. create 2 tracks (on left side of GUI) in T-Author, and then create menus with chapters (scene selection) within each track (movie) if you want.
    3. take output to Shrink if downsizing is required.
    good luck.
  3. This might help also.
    http://www.myguides.0catch.com/Guide.html
    This is not "my" guide, but one from the guides section.
  4. andkiich
    he needs menu(s) and the guide you specified does not create them...
    "The disadvantage is that I cannot use any menus and have to select different titles with my DVD Player's remote control."
