Hello everyone.
First of all, I should mention that it is THE BESTsite I've seen so far. Thanks to all.
This topic for converting PAL to NTSC has been brought on many
ocasions, but after searching and reading information for couple of
months, I am now confused more than ever. Your help on this matter will
be greatly appresiated.
So, I have several PAL (25 fps) AVI's and MPEG's with different ratios
(352x288, 480x352, 528x416, 640x480). I need it to convert to NTSC
(VCD, SVCD). The final output is DVD for standalone DVD player.
Tools: TMPGEnc Plus, TMPGEnc DVD Author, VitualDub(Mod), BeSweet,
Gold Wave, Nero6.
Questions:
VIDEO
1. Do I have to convert to 23.97 fps and than to 29.97, or strait to 29.97?
What filters should I use for that in TMPGEnc and when (Frame rate,
3:2 pull, etc.)? Will it be ok, if I do just 23.97?
2. Video Arrange Method is Full Scr (keep aspect), but after clipping the
aspect will change (exmpl. 312x240), is that will work fine on DVD, TV?
3. Should I use CBR, if size does not matter? If VBR, what would be max
and avg settings?
AUDIO
1. As far as I understand, I have to convert to MP2 48kHz and about
128kbs. It that right?
Thanks to all in advance.
Felix
Changing AVI Properties (Resolution, FPS etc) NTSC>PAL
By skywalka in forum Video ConversionReplies: 4Last Post: 7th Mar 2011, 20:45 -
mencoder options NTSC 29.97 -> PAL 25 fps with a/v sync
By menket in forum Video ConversionReplies: 3Last Post: 8th Oct 2008, 07:04 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17 -
FPS NTSC & PAL Film/Digital
By flamingo in forum Newbie / General discussionsReplies: 5Last Post: 13th Nov 2007, 13:21 -
FPS..NTSC & PAL Standard Cinema Film/Digital
By flamingo in forum TestReplies: 0Last Post: 9th Nov 2007, 08:30
