hi there,
lets see if i can explain this to you.
i'm trying to join 2 xvid files so then i can use TMPGEnc to prepare them for dvdr, i join the files with virtualdub then as usual i tryed to extract the audio <full processing mode>compression =NO Compression (pcm) and save wav.> and it gives an error <No audio compressor could be found to decompress the source audio format> i have all the codecs instaled and i really dont no how can i extract the audio to be used with TMPGnc.
I would really apreciate if someone could help me out as ive got the drive full of xvids and cant put to dvdr, if you know a better way to convert them or know a guide i will be very thankfull.
Sorry about my english, i know its not very good, but im still trying
TIA to anyone who helps this desperate person...
99% chance it has AC5.1 Audio. Install the free AC3 filter in the tools section.
AC3 is fine for DVD's.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
do u mean in the tools on virtualdub ? i did get the file and tryed to instal but nothing seams to happen.....
do i still follow the normal way after i get the audio extrated ?
sorry for beeing so NEWBY
No audio decompressor could be found using VirtualDub
By dapster in forum Newbie / General discussionsReplies: 22Last Post: 6th Jun 2015, 05:25 -
VirtualDub - No audio decompressor could be found.
By kelemvor in forum Video ConversionReplies: 25Last Post: 24th Jan 2013, 17:36 -
Vorbis decompressor for virtualdub
By mkr10001 in forum AudioReplies: 2Last Post: 14th Mar 2012, 13:58 -
[solved] virtualdub + no decompressor prob...
By j6044 in forum EditingReplies: 18Last Post: 4th Sep 2010, 08:14 -
Virtualdub Xvid Decompressor problem
By unkown in forum EditingReplies: 12Last Post: 13th Aug 2007, 20:38
