Hey.
I got a video and want to convert into a VCD. It is 20fps and I figured that if I convert it, it will play jumpy because of the missing frames. Is there anyway around this?
Coz one time I converted a NTSC movie into PAL vcd and it did play a little jumpy.
Any advice???
Thanks.
There is no way (that I've found out) to convert a 20 fps avi to either NTSC nor PAL. You can't regain the frames that have been removed, only make copies of existing frames to "fill the blanks". This will give you a jerky movie with strobe effect.
To convert to from PAL/NTSC is pretty easy.
Use Vdub and CoolEdit (or some other sound editor)
Save the wavefile.
Change framerate to desired and save avi.
Open the saved avi and go to the end and note the duration.
Open the wave file in cooledit go to transform, put the new time in and save the wav.
Atfter that incorporate the wave in your avi (change the preload time to synch sound) and save.
Encode and burn.
converting PAL (25fps) to NTSC(23.97fps) with audio
By drew24 in forum MacReplies: 6Last Post: 21st Dec 2009, 10:45 -
which muxer handles NTSC 704x480 2.21:1AR 29.97fps mpeg2
By halsboss in forum Video ConversionReplies: 12Last Post: 3rd Mar 2009, 21:39 -
Best way to get 29.97fps progressive video onto NTSC DVD
By Ste in forum Video ConversionReplies: 6Last Post: 23rd Oct 2008, 14:59 -
Converting 30fps to 29.97fps ?
By blewyn in forum Video ConversionReplies: 2Last Post: 19th Mar 2008, 11:24 -
24fps HDV (NTSC) to 29.97fps DV (NTSC)
By vodnick in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 3rd Jan 2008, 07:36
