  1. I' ve been converting using tmpeg for a while but just got a new computer. Now when I try to convert an Mpeg-2(svcd) to dvd I cannot open the file. I keep getting "unsupported". I've installed all codecs(divx3,5, ffdshow,ac3, Windows media 9) Waht the heck am I doing wrong or what have I forgotten.
    Dec 2002
    Did you install an MPEG2 codec? Free one in the tools section.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  3. Yes and it still doesn't work
  4. which file type are you trying to convert?
  5. skasino,
    I know this may sound funny, but give it a shot anyway.
    I found that when trying to open files in TMPGEnc, if they're a bit too deeply buried then it won't open them, saying they are unsupported. Moving the file to the desktop will cure this.
    Unlikely to be the source of your problems, but worth a shot.
    Otherwise, you might want to try this method here:
    https://www.videohelp.com/forum/userguides/171216.php
    Hope this helps
    CobraDMX
  6. Just install powerDVD! or any DVD player soft.
  7. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Read my sig, second link.
  8. Try installing the mpeg2 plugin. https://www.videohelp.com/tools?tool=243#comments for TMPG.
