I have been trying to burn a movie that is in a .bin/.cue file format.I 'm using nero 6,when i click on burn dvd i get a message saying that (your compilation cannot be written to this disk.)i have tried using a dvd-r and a dvd-rw and get the same message.What do i need to do to burnthis file?![]()
Results 1 to 11 of 11
You are opening the CUE file right? Are you sure it's the right CUE? You can mount the image then do a disk to disk copy. You can use ISO buster to extract the files then you can re-burn.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
when you say mount the file do you mean to burn it to a cd then do disk to disk?
Are you trying to burn from image or are you going straight to burn VCD?
Maybe I don't understand. My only bin/cues are from DVD2SVCD
To burn the bin file I have to open File>Burn Image. That opens an Explorer window looking for .nrg, .iso, .cue files. If you have a bin and a cue, click on that cue and nero gets instructions or a pointer or whatever to burn the bin file.
Of course I have selected VCD/SVCD as the format to burn to.
If this is no help, I must not know what you are trying to do.
Sorry.
George
Sorry again, but you are trying to burn the bin file, that is the bulk of the movie or whatever. My cue files are only 300 bytes or so, pointers and directions. -
It sounds like your trying to burn an image to a dvd, I think bin/cue are only for cd,s like VCD,s. To Burn a standard DVD u need vob files. Maybe im wrong, im not 2 sure myself.
Try using Daemon Tools (freeware). It creates a virtual drive on your machine and converts your bin/cue files to a virtual CD which can be played for testing and burned using the disc to disc copy function in your burning software. All this may sound vague, but it is actually very easy to use. I never burn without it.
yes i am trying to burn bin/cue to a dvd.These are the file formats the movie came in.Should i convert these files to a different format?If so what program do i use.
Almost undoubtedly, the CUE/BIN image is an image of a CD.
You cannot burn CD images on a DVD for one obvious reason, a DVD is not a CD.
Regards.Michael Tam
w: Morsels of Evidence
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 12:58 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 11:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29
