hi all,
have a .vob file with dvdpcm-audio for encoding to svcd.
After the video stream has been encoded correctly,
the encoding stops with:
INFO: [yuvscaler] End of stream!
INFO: [yuvscaler] Normal exit: end of stream with frame number 3779!
INFO: [mpeg2enc] Guesstimated final muxed size = 24238571
a52dec-0.7.4 - by Michel Lespinasse <walken@zoy.org> and Aaron Holtzman
No accelerated IMDCT transform found
0 frames decoded in 0.00 seconds (0.00 fps)
**ERROR: EOF in WAV header
**ERROR: failure reading WAV file
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File /Volumes/WD_Daten/concrete/einzeln/10/Concrete_Blonde_PAL/movie.m2v looks like an MPEG Video stream.
**ERROR: [mplex] Unable to open file /Volumes/WD_Daten/concrete/einzeln/10/Concrete_Blonde_PAL/movie.mp2 for reading.
Any solutions ?
I assume that you're using ffmpegX 0.0.9a. Could you please email me the complete process output to major4@mac.com
No sound from a PCM audio stream using DVDFab DVD to AVI file.
By loninappleton in forum AudioReplies: 8Last Post: 5th Dec 2011, 05:27 -
How to convert PCM audio track inside M2TS file
By majouz in forum Software PlayingReplies: 1Last Post: 20th Jun 2011, 15:24 -
Help Please Vob file problems
By Kwalsh11 in forum Newbie / General discussionsReplies: 1Last Post: 13th May 2010, 03:41 -
Playing PCM audio within AVI file
By acid_burn in forum Newbie / General discussionsReplies: 1Last Post: 25th Dec 2007, 04:27 -
Converting VOB file to MP4 file. Video is perfect, audio is nonexistent.
By jdfrosty in forum ffmpegX general discussionReplies: 6Last Post: 17th Jul 2007, 19:31
