I created an image file of a SVCD .mpg file using VPC4 and Nero. The extension is .NRG
To burn it with Toast 5, do I need to convert it to .bin then put it through binchunker or what??
Dave
if you already have the .mpg file in compliant format, don't use Nero but VCDImagerEasy (under VPC emulation) and select the SVCD option and the Toast option. You will get two XA tracks ready to be burned under Toast XA window.
major
Thanks so much for the tip.
Before your reply, I couldn't get VCDimager Easy to work but I created a new CDrive and reinstalled VCDImager Easy and have been converting and burning those .mpeg SVCD movies that I've been storing.
Only gripe is that it takes a couple of hours on my B&W G3 to convert the .mpegs to the XA files.
Appreciate your advice.
Dave -
there is a way to do it quicker if you've got OSX : install VCDImager for OSX and run it from command line. You will be done very quickly!
Thanks again! I'll keep that in mind. I haven't got OSX installed but I have it.
Happy Trails,
Dave -
many image files are interchangable. Try renaming your file to .img and mounting with DiskCopy. If this doesn't work then go back to nero and make an iso image instead of an nrg.
.nrg file conversion
By PULINC in forum Video ConversionReplies: 3Last Post: 7th Apr 2012, 03:10 -
.nrg file
By firoril in forum Video ConversionReplies: 1Last Post: 13th Jun 2008, 03:25 -
How to convert dvd image file to .Avi
By AkaTaKlysm in forum Newbie / General discussionsReplies: 5Last Post: 15th Apr 2008, 11:02 -
HELP PLZ! is it possible to convert and ISO image to another file type...
By carapalida in forum Video ConversionReplies: 13Last Post: 7th Apr 2008, 18:58 -
How to convert NRG files to AVI?
By Rude in forum Newbie / General discussionsReplies: 6Last Post: 2nd Apr 2008, 14:05
