Hi,
I have a question:
I capture using MMC 8.7, AVI using Huffy. Everything is fine.
Then I open the video file in VDub (1.5.4 or 1.5.7) for editing (cutting, apply some filters etc). Then I go "Save as AVI...", then......the new AVI file is BIGGER than the original!!!! What is happening??? Also using Huffy in VDub. The final file created by VDub is more than twice the size of the original AVI captured with MMC. Even when I am not applying any filters in VDub, the AVI file size gets bigger....
any ideas???
Compression, compression, compression! If the file is larger, it must be less compressed or uncompressed. If it's smaller, it must be compressed someway. Huffy is about the best lossless codec there is with 2:1 compression. Don't know what codec MMC uses. But remember: Compression is the King.
VirtualDub question
By s3r19lk1ll3r in forum EditingReplies: 5Last Post: 15th Oct 2010, 16:43 -
VirtualDub question
By Rogert in forum Newbie / General discussionsReplies: 5Last Post: 18th Aug 2009, 11:22 -
virtualdub question
By thecrock in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2007, 12:34 -
virtualdub question
By cowboysroy31 in forum Newbie / General discussionsReplies: 5Last Post: 21st Jun 2007, 11:50 -
noob question...about VIRTUALDUB....
By SeeNoEVO in forum Video ConversionReplies: 1Last Post: 1st Jun 2007, 01:07
