Hey all, I've been trying to get this divx to load into my DVDSP2 and compile. It allows it to go in, but then when I try to build the disk I get video bitrate too high. Then I took the divx and re-encoded it into MPEG2 using Quicktime and I still get video bitrate too high. My friend then converted it using TMPGEnc or something on the PC, and that file doesnt even load. Any suggestions on how I could finish up this project? Thanks
Sincerely,
Mel
I think you're getting this message because you're dragging the file into DVDSP and letting it handle how to encode for DVD. When building a DVD from this approach, DVDSP encodes the audio into uncompressed PCM, which uses a great deal of the available bandwith in a DVD stream. To avoid this, you should encode the video and audio separately outside of DVDSP. Use Compressor on your video; export your audio to AIFF (in QuickTime if your audio codec is supported). Then take your AIFF file to A.Pack and convert it to a Dolby Digital stream. Import your new MPEG-2 video file and your AC3 file into DVDSP and author. The error should be gone.
Do some research in other threads to learn how to resolve sync issues from DivX files -- because 9 times out of 10, you're going to have sync issues.
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 20:53 -
Video in PAL and Audio from NTSC source
By jairovital in forum Authoring (DVD)Replies: 30Last Post: 17th Jun 2010, 13:16 -
FitCD assumes source is PAL
By sambat in forum Video ConversionReplies: 5Last Post: 3rd Sep 2008, 17:42 -
Having difficulty evaluating PAL DVD source
By Blind Pew in forum Newbie / General discussionsReplies: 5Last Post: 5th Apr 2008, 22:26 -
Help with possible interlaced pal avi source
By h2p000 in forum Video ConversionReplies: 4Last Post: 28th Feb 2008, 17:41
