Hi,
Got this player 2 days ago and slight problem...
firstly i have verbatim discs, i write @ 24x with closed cd's.
Now i have svcd, vcd on these discs, they work perfect..
Next I have 3 avi files of friends episodes on 1 disc, they play fine, but when i try to play a full avi movie = disc error, ive probally tried it 50 times and 2 times it acutally played the movies, so is it the discs? is it the player? I also have the lastest firmware installed...is there anything I can do to fix this....
sounds like the disc is faulty if plays other discs ok, and this disc plays once in 10 tries. I use phillips cdrw and infiniti CDR which seem to work fine.
Its seems to be with all the avi discs though...so is it an avi burning issue maybe? i will try buring movies on other discs also...Originally Posted by RabidDog
you just burn any avi files to disc as a data disc. Nothing special needed. play the discs in your computer to check them.
getting the Toshiba SD-6100 code free
By geeg in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2010, 08:03 -
Help with a sound issue on a Toshiba SD-6100
By hhcup in forum DVD & Blu-ray PlayersReplies: 1Last Post: 9th Apr 2008, 10:06 -
NVIDIA GeForce 6100 Vs Radeon 9550
By the_importer in forum Media Center PC / MediaCentersReplies: 5Last Post: 12th Nov 2007, 17:59 -
yamada dvr-9300hx
By omz4life in forum DVD & Blu-ray RecordersReplies: 2Last Post: 14th Aug 2007, 11:37 -
Yamada 8500x
By tomkittenuk in forum DVD & Blu-ray RecordersReplies: 6Last Post: 3rd Jul 2007, 18:25
