I'm wanting to download a film and then convert onto dvd which format is best to start with i have been told divx ???? is this true
Your question shows that you have done no back reading on the subject. Read some of the guides here and they will help.
For dvd you need to convert to mpeg2, divx is a form of compression (avi). -
Ditto hardcoreruss. If your question is "what format of film to download is best to make a dvd then the aswer is a dvd format film. If your question is what format to convert it to AFTER you download it then the answer is dvd format(mpeg2), which is the ONLY format if u wanna make a dvd.
Recommended Format? Digital8 video to PS3 or PC format?
By fuzzysword in forum Video ConversionReplies: 5Last Post: 26th Apr 2010, 07:19 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 20:00 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 08:21 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
