I have a avi file and when I load it up on TMPGEnc "File can not open, or unsupported" The audio source worked but the video source didnt. What do I have to do to make this avi file into a vcd file
try an other VideoCodec (e.g the krystal codec, can be founded on this site..)
or try to use VirtualDub and there is an option when you select open.. then there is a optionmenu.. check the reclaim something..
and then use Start Frameserver.. -> save the file as movie.avi (this file is a dummy)
you can find more information about frameserving on this page..
then you should be able to encode the movie.avi
AVI to VCD
By Slip Kid in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2009, 01:40 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 16:34 -
Tmpgenc to avi
By mrcoolekin in forum Video ConversionReplies: 3Last Post: 15th Aug 2007, 00:10 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
