i see real dvd's with options on the first screen when you put the dvd in the dvd player , the options i would like on my burned dvd is the two option i see on real dvd's, the two option i want both which one button to hit is to play all the videos and another option to pick which videos i want to play. i will have 14 different 8 minute videos..
i want a button to play them all and another button to be able to pick from the 14 and play each one.. is this possble with ulead moviefactory 2 se.. ive tried going thru the program and cant se how to do this?
thanks
There should be a button there after you burn if you have more than one title or chapter. When you start up the DVD it will simply look like a play button. That plays all, from the beginning.
EDIT: To clarify, this button will usually be on the botom of the screen -
so the all play buttom will be added automatically? i dont have to add that option to the menu all i have to do is do the pick option on my own?
thanks -
As far as I know all menus you make come with a play all button. If you pick it, assuming this is the top menu, it will play title 1, scene 1. If you are in a different title submenu and pick it, that title's scene 1 will play.
Blu ray menus with ULead Movie Factory 6 +
By mobie29 in forum Authoring (Blu-ray)Replies: 1Last Post: 31st May 2010, 17:50 -
Ulead Movie Factory queries
By Mark Wynn in forum Authoring (DVD)Replies: 2Last Post: 11th Apr 2010, 21:42 -
alternative to ulead movie factory
By marlo in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2008, 04:48 -
Problems with Ulead Movie Factory
By merkuria_lyn in forum Authoring (DVD)Replies: 4Last Post: 25th Oct 2007, 14:12 -
Ulead Movie Factory 6 plus
By ictaylor in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 03:20
