I accidentiliy removed the login program in winxp. It says I am missing a file now but windows won't boot. And for some reason I can't boot from the cd? anybody have any suggestions or maybe how to make a floopy boot disc for xp pro?
Is the file your missing NTLDR??
If it is just boot from the a:98 boot disk then copy the NTLDR file from your XP install disk to you root director, usually c:\
*EDIT* Forgot, Sometimes mine when boot and it says "Missing NTLDR" I have to reset the CMOS/BIOS to fix it (pop battery out). Also you probably won't boot from a CD cause your BIOS Boot sequence is wrong XP CD-ROM isn't a bootable disk to start windows it will only let you repair, reinstall, etc... You can make a bootable floppy though -
Thanks for the reply. I can't boot from 98 because I have already formated the drive to ntfs. I found the floppy download and used it to repair my system so all is well thanks!!
Save with hotmail
By Jomapil in forum ComputerReplies: 3Last Post: 3rd Jul 2011, 12:15 -
MPEG-2 edit/save, edit/save, edit/save... cycle
By KZemunski in forum Newbie / General discussionsReplies: 8Last Post: 26th Dec 2010, 15:55 -
What camera should I save towards next
By photoelectricgeek in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 23rd Aug 2010, 02:44 -
ho to save?..
By im faster in forum Newbie / General discussionsReplies: 7Last Post: 7th Aug 2008, 07:16 -
Help - Can't save to SD Card
By jenvance in forum Off topicReplies: 0Last Post: 19th Feb 2008, 20:10
