Ok, I have the TMPGEnc program. BUT from what I can tell it only converts AVI. and MOV. (with the added thingy). IS there anyway to convert just plain old mpegs. to mpeg 1? I have mpegs and everytime I try to convert it to mpeg 1 it says something about it being an invalid file. So I thought it was already converted...but when I tried to burn it would not work, CAN SOMEONE PLEASE HELP????...
Thanks a lot
when you pick your source file you have the option to select mpeg files as a file type.
try using the MPEGproperties prog in the tools section to your left. It will give you properties such as bitrate, screen size, and fps, etc.
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 9th Apr 2009, 23:56 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 28th Aug 2008, 23:33 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 00:17
