Im using TMPGEnc to convert. At frist i tried to just load the xvid file in tempgenc and use th wizard to make it DVD ready. But it kept giveing my like 7.4 gigs size instead of 4.0 like it should. So i read on here somewhere that i should convert the audio. So i loaded up vdub and extracted the .wav. Then i loaded it all up in tempgnce and the file size did come out correct. so i went a encoded it. But then after i watch about 10mins for the mpeg i noticed that the sound was out of sync...
what should i do?
Bad frames? See below.
"Art is making something out of nothing and selling it." - Frank Zappa -
As you didn't notice this until after 10 minutes, could it be the dreaded gradual sync loss? Then it's probably due to frame rate conversion. Does your source AVI and target DVD m2v have the same frame rate?after i watch about 10mins for the mpeg i noticed that the sound was out of sync
If it's off from the start, the audio and video in the AVI is probably interleaved with skew, meaning that the audio starts after the video in the AVI. When you extract the audio, this skew is lost, and has to be taken into account either by adding the same amount of silence at the start of the audio, or by multiplexing with offset/skew.
/Mats -
play around with your environmental settings first, and also set the bottom field in the wizard to "film movie"
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"?
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 14:35 -
Does xvid cli (command line version of xvid) actually exist ?
By vhelp in forum ProgrammingReplies: 10Last Post: 29th Oct 2009, 15:18 -
help combining 2 xvid avis and 2 subtitles (srt) to 1 xvid avi
By hibbs in forum SubtitleReplies: 4Last Post: 14th Jun 2009, 20:05 -
How to encode an xvid file to another xvid and prevent video blocking?
By BlooderButcher in forum Video ConversionReplies: 5Last Post: 21st Nov 2008, 17:03 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47
