  1. Hello. I have lots of random files of many many different formats. I want to convert them to the most basic video format(mpeg?), and i'm not sure what the best program to do this would be. Like i said they are all different formats, and i want to know if there are any programs that support lots of different formats. Thanks
    Apr 2002
    The State of Frustration
    Try TMPGEnc.
    Hello.
  3. I have that. There are a few files i have that it says aren't supported. I know they're some sort of DivX files. I still want to convert them but dont know how.
    Apr 2002
    That is when you use Virtual Dub mod. Also, you may need a copy of GSpot. Use Virtual Dub to frameserve your DivX files to TMPGEnc. GSpot is for when you get a file that your computer does not have the codec. GSpot will tell you which codec you need.
    Hello.
  5. where is the best place to get codecs. I just want the codecs not the players and stuff that installs all of the adware if possible.
  6. Originally Posted by NooBlue
    Theres a website called www.dvdrhelp.com, they have links on the left side of their website, under tools there's a section called: Codecs, I get my codecs there.
    Ejoc's CVD Page:
    DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
    DVD:
    DVDShrink -> RecordNow DX
    Capture:
    VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
  7. Член BJ_M's Avatar
    Jul 2002
    Canada
    or use programs like ulead or vegas or premiere pro and just drop all your stuff on the time line and render it out as however you want - they dont care what the input files are ...
