    Sep 2001
    I am trying to use Virtualdub to convert a DV .avi file to a Divx file. I open the DV file in Virtualdub and set the beginning and ending frames. I set the video to Fast Recompress and the compression to Divx 5. I set up all my Divx settings, then do Save as .avi. It gives me the following error:
    VirtualDub Error:
    Cannot start video compression:
    The source image format is not acceptable.
    (error code -2)
    I am using the raw .avi file I captured from my Digital 8 camcorder. Can virtualdub not work with this file?
    Thanks in advance.
  2. I haven't dealt with DV, but I heard VDub can't deal with type 1 or type 2 DV directly. You may have to run it through a DirectShow filter through AVISynth to make it work. That's what I heard and I don't know if it's true or not....
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    virtual dub can handle dv files fine -- just install the main concept dv or panasonic dv codec first ...
    Sep 2001
    I have the panasonic DV codec installed and it still gives me the error. I can open the DV file fine, it is just when I try to convert it to Divx that it has a problem.
    Any other thoughts? How do you use avisynth to turn a DV avi file into divx? I couldn't find a guide on it.
    Apr 2002
    The State of Frustration
    Well, if the DV file is a type 2 DV, the AviSource command should open it, since it is AVI. Have you tried to reload your DivX codec, yet?
    Hello.
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    you may have to restream the dv file in that case (not unussual) ..
    just open it up , set compression to the panasonic dv codec you have (i know this works with the MC one and i assume it will also with the pana one)
    then fast recompress to a new file ..
    it should work for you then ...
    Dec 2002
    If it's a Type 1 DV, convert it to Type 2. That always helped me getting it to work.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
    Sep 2001
    Nope, that didn't work either. Same error message. I'm running out of ideas!
