has anyone seen or have the new sony pci capture card i saw it at a local department store (meijres) it is the sony ez vidio systeme need info on it
Results 1 to 11 of 11
I thought that was old technology that appeared to be based on pinnacle products.Originally Posted by tjbecht
according to sony web site it is new and is the first time i have seen it or heard of it is it worth the 95 bucks for it it does have the three rca jacks on it for the video and the audio
Can you post a link to this product on the SONY website?Originally Posted by tjbecht
- John "FulciLives" Coleman
P.S.
I guess I was confusing it with another older SONY product."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
go to sony.com and then click on software then go down to entertainment software and click on view all products scroll down till you see sony ez video in a green and black box
Well I was hoping for a direct link because I've found over the years that the various SONY websites are friggin' nightmares to navigate. I don't know what a-holes do the SONY websites but they clearly are confused as to how to make a site easy-to-use.Originally Posted by tjbecht
So I go to SONY.COM and I see NOTHING on the main page that says SOFTWARE. Figures.
So I do a search on "ez video" and this is what I came up with:
http://www.sonystyle.com/is-bin/INTERSHOP.enfinity/eCS/Store/-/-/-/SY_DisplayProductIn...ories_EZEditor
I don't know if this is what you mean or not. It is some sort of analog video to computer device but it says it only has your standard 3.5 mm audio jack (not seperate Stereo RCA type jacks as you indicate).
Anyways I see nothing special about this at all.
that is it and it does have the audio rca jacks cuase i opened one at the store and looked at it it sounds and looks like a good piece of equiptment
Well why does it sound like a good piece of equipment? Just because it has dedicated RCA audio jacks instead of a 3.5mm headphone type jack?Originally Posted by tjbecht
I mean just because SONY makes it doesn't mean it is good.
We have no reviews of it including user reviews.
We don't know much about the hardware such as what kind of chips it uses for doing the conversion process etc.
Too many unknown's right now to say that it looks good.
And Princo and CMC looks like a good disc.
it looks like a good piece cause it is a one piece card no extra connections or wires to run plug and play type of set up i will be purchasing it soon and will write a review on it after install and first use
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Built In Multiple Card Reader Won't Recognize SD Card
By V Bot in forum ComputerReplies: 9Last Post: 8th Oct 2011, 00:01 -
[VHS conversion] Sound Card, Video Card?
By bessiecat in forum Capturing and VCRReplies: 6Last Post: 26th May 2011, 14:02 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51
