Well, i wouldnt really call this a problem, but it might cause a problem. But when i backup a dvd using dvdshrink, and i put the files into nero and go to burn, before it actually starts i get this little message that pops up.
That says:
whats what it says, and i usually say no, because i dont want to risk making a coster. Then is just stops all together, and thats it. Would it be safe to go on? Or is there a problem?DVD-Video files complience test failed. The resulting DVD-Video might be unplayable. Do you want to continue?
What si the actual warning (what you wrote is incomplete)
thats it, thats all the little window that poped up said.
Heres a copy of the log
Thats the log that comes up in nero. But i dont understand how the fles would be differentBackup file 'VTS_01_0.BUP' should be identical to 'VTS_01_0.IFO'
Backup file 'VTS_02_0.BUP' should be identical to 'VTS_02_0.IFO'
Backup file 'VTS_03_0.BUP' should be identical to 'VTS_03_0.IFO'
VD-Video files compliance test failed
The bup file is just a backup of the ifo file, so it wont make any difference.
Just burn it and it will be ok.
If you wanted to play safe, you could copy & paste the 3 ifo files to your desktop, rename them with the bup extension, then delete the offending bup files (in the VIDEO_TS folder) and copy & paste the renamed ones back in their place.
Then try burning with Nero and see if it stops complaining
Ps2 Burning Problem
By waazzaa101 in forum ComputerReplies: 17Last Post: 21st Jun 2012, 20:47 -
Problem with burning.
By googoodolls in forum DVD & Blu-ray WritersReplies: 7Last Post: 12th Dec 2009, 07:20 -
Problem with Burning DVDs
By The Monkees in forum MacReplies: 2Last Post: 25th Oct 2009, 02:00 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Burning tracking problem or software problem???
By yogart in forum Authoring (DVD)Replies: 2Last Post: 24th May 2007, 13:39
