I have 2 single layer DVD 5 movies that I wanna try to copy. Both are MGM movies, Hackers & Bill & Ted's Bogus Journey. I have used DVD Decrypter & DVD Shrink 3.0 Beta 5 to rip. As per the guides on this site. & I have used Nero 6, DVD Architect 1.0, & DVD Decrypter to burn what i ripped. The DVD's were single layer & did not exceed 4.38 GB. They burned fine without any errors. But the problem starts when I put the DVD into my standalone player, Apex AD-500W, the DVD will begin to read & then make noises like a printer. I then tried it in my PC's DVD-ROM drive & my standalone Classic DVD102, it works without problems. I have also backed up other DVD's (DVD9 to DVD+R) & have had no problems at all. Can someone please, help shed some light on the situation as to why I can't back up these DVD's. Thanks in advance.
Results 1 to 11 of 11
Father knows best.
The Aopen2412 is a Ricoh clone that is capable of bitsetting.
Which booktype were you using?
BTW I don't understand why you use so many programs for backing up single layer DVDs.
All you need is DVD Decrypter:
1. ISO read
2. ISO writeYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
dudeman316
you have backed up these movie. they just don't play on your apex. you have any other dvdr from a dvd5 that plays in it? media incompatibility? -
tompika: I am using DVD-ROM book type in Nero & i tried so much other software just to make sure it wasn't a software issue.
noki:I then tried it in my PC's DVD-ROM drive & my standalone Classic DVD102, it works without problems.
Do either of you think it may be possibly a media issue or do u think it is simply just my Apex player. I just backed up the movie Three to Tango, (not an MGM title), plays fine in the apex player, with the exception of the theatrical trailer not working when i choose it. & Again this is with the apex player only.Father knows best. -
dudeman316
what is the media id code of the dvdrs that won't play properly in the Apex? -
i think this is it
they are Philips DVD+RW's
DVDRW/013
9307 002 60013
I have used this media & burned other DVD's (DVD-9 to DVDR) & they work fine. It just seems like it's these MGM DVD's.Father knows best. -
Does the information help ya out any??? BTW just recently did a copy of 10 Things I Hate About You, it was single layer DVD & it copied it to memorex DVD+R using DVD Decrypter. It works flawless.
Try buying a couple nice DVD+R's. If you're just nipping out to the store I recommend Fuji or Imation.
- Gurm -
Originally Posted by dudeman316
When you finished shrinking the VIDEO_TS use IMGTool Classic to make an ISO and burn it with DVD DecrypterYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
My HP printer D5360 died, looking for a new DVD printer
By stiltman in forum MediaReplies: 9Last Post: 18th Mar 2011, 23:04 -
portable DVD player cracking sounds then hangs
By dzsoul in forum DVD & Blu-ray PlayersReplies: 5Last Post: 29th May 2009, 06:29 -
DVD audio sounds high pitched
By nopulse in forum Newbie / General discussionsReplies: 3Last Post: 19th Nov 2007, 19:31 -
DVD to ipod sounds like a chipmunk no matter how I convert
By nukular in forum ffmpegX general discussionReplies: 3Last Post: 11th Sep 2007, 18:00 -
mp4/psp sounds problems
By Nick1982 in forum Newbie / General discussionsReplies: 1Last Post: 21st Jul 2007, 15:22
