Please help,
I am a newbie to DVD burning. I purchased a Pioneer DVR106D with firmware 1.07, using DVD Shrink 2.3 and Nero 6.0.0.0. The shrink was fine but the burn at 2x and 1x resulted in the following error. Please help
PS. I was successful using IMG Tool Classic .90 Build 8 and DVD DeCrypter after the shrink. But I'd rather have 2 steps to burn instead of 3.
Thanks in advance
3:24:17 PM #39 Text 0 File dlgbrnst.cpp, Line 1678
Set remaining time: 0:00,000 (0ms) -> OK
3:24:17 PM #40 CDR -1064 File WriterStatus.cpp, Line 160
Invalid block address
3:24:17 PM #41 TRANSFER -24 File WriterStatus.cpp, Line 160
Could not perform end of Disc-at-once
3:24:17 PM #42 Text 0 File dlgbrnst.cpp, Line 1678
3:24:17 PM #43 Phase 38 File dlgbrnst.cpp, Line 1818
Burn process failed at 1x (1,380 KB/s)
Results 1 to 12 of 12
nero 6 = Bug, so dont use it. Use instead Nero 5.XX versions. 8)
Originally Posted by apurcell
Thought it might be that the file was too big, so I shrunk it again, this time the DVD burned OK, but when I wanted to play it on the standalone players I've got it gave me the following error: "parental violation"..
So if anyone got any good suggestions, I'll be waiting.. tnx. -
Just upgraded to Nero 6.0.0.23 version, still receiving the same error as above. Tired of making coasters (5 so far). Gonna stick to Shrink 2.3, then IMG tools, then DVD Decrypter. I would like to keep it to 2 steps instead of 3 if possible, if anyone has any ideas it would be appreciated.
Originally Posted by goindimon
1. Use DVDDecrypter, DVDshrink and burn with RecordNowMax, but
2. I want to do the job in one pass and still be in control what I want to have on the DVD. So I use AnyDVD (bypasses the security of the DVD). This neat little program sits on your comp and you don't have to rip the DVD. When inserting the DVD I use CloneDVD, which cannot open locked DVD's, but with AnyDVD it's no problem. After that I put a blanc DVD in my burner and press GO.. within 2 hours the DVD is backuped...
Hope this will help you.
Grz -
hi. i am currently trying to back up my dvds using nero 6. I have decrypetd and compressed using DVDdecrypter and DVDshrink. When i go to burn it scans files but will not continue. does not say there are any errors, doesnt quit it just idles. If anyone can help it will be very appreciated
Originally Posted by nismoGTR
Tip: Try to burn first on a DVD-RW. If it doesn't work, you can erase it and try other options. Otherwise you could lose a lot of DVD's.
Grz -
Well here's my latest update:
Moved my burner to another pc, instead of Shrink 2.3 I used latest ver 3.0 Beta 5. Instead of Nero 6.0.0.23, I used Nero 5.5 with latest patch (also removed the crive from USB 2.0 encloser and physically connected in bay,hmmm?) . Viola, all worked fine, BUT when I went back to original PC and used Shrink 3.0 Beta 5 and uninstalled Nero 6.0 and reinstalled Nero 5.5, I got the same blasted error. Arghh (6th coaster)
PS: I did try to burn on a DVDR+W successfully before the burn onto a DVD-R. This is too weird, PLEASE ANY RECOMMEDATIONS WOULD BE GREAT. Getting frustrated and wasting DVD's. -
Hmm, again I would suggest you to move to another burn program. It's worth the try believe me... I'm burning DVD's as easy as can be without any errors..
You can pm me if you want further details... -
It happened with me too. I discovered the problem. In my case, it was a virtual drive program that I used to emulate a DVD unit from an ISO file. I've removed it and everything is working well now.
Burning DVD Could not perform end of disk-at-once
By jasonkral in forum Authoring (DVD)Replies: 8Last Post: 13th Feb 2011, 23:05 -
By smt16 in forum DVD RippingReplies: 1Last Post: 18th Jun 2010, 05:50 -
Could not perform end of disc-at-once on dual layer dvd only
By Subhash in forum DVD & Blu-ray WritersReplies: 20Last Post: 25th May 2009, 13:09 -
By mrjoetoff in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2008, 13:27 -
Error: Could not perform end of Disc-at-once - Please Help
By patrickj0781 in forum ComputerReplies: 7Last Post: 20th Jun 2007, 19:28
