Hi. I just downloaded EO-Video and tried converting a MOV to VCD, and everything worked but the audio was out of sync of the video. I have the latest Quicktime and the latest EO-Video release. I've heard people usually encounter audio/video sync problems with MOV conversions, but I'm sure there's a way around it. Please advise!
When you converted to VCD, was it in MPEG format?
Hello. -
No, it was VCD with all the default options. Maybe the MOV isn't NTSC, or even PAL. On a side note, how can I check the info. on the MOV clip? All quicktime told me was the resolution, not the bitrate or FPS...
You can also try the trialware version of Video Studio 7. It can take a MOV file and burn a VCD from it, among other formats. Also looking at the properties of a video file in VS 7, it will tell you a lot more info.
Hello. -
I've had the most luck converting .mov files without sync problems using the Export feature in Quicktime Pro. This, of course, will cost you ($30 I believe) for the Pro version.
Open WIDE for Chunky!!! -
hey I had the same problem what u need to do is find a converter with audio vid sinc. that should clear up ur problem
Yes VideoStudio is great but TMPGEnc will do,make sure to d/l the TMPGEnc MOV Plugin .
.MOV conversion to .AVI and .MOV HD quality query
By Peewitisland in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2011, 11:22 -
Mov conversion help?
By Timbo78 in forum Video ConversionReplies: 2Last Post: 13th Sep 2010, 06:10 -
.mov to dvd conversion
By tomm2000 in forum Video ConversionReplies: 1Last Post: 7th Sep 2007, 16:23 -
.mov to DV conversion
By aaron_rip in forum ffmpegX general discussionReplies: 4Last Post: 3rd Jul 2007, 16:55 -
AVI to .Mov conversion
By HD_Shooter in forum MacReplies: 10Last Post: 18th May 2007, 07:45
