Does anyone know anyway to improve the audio quality besides using an external tool like toolame.
I use toolame, but the quality still turns out to be really soft, I have to turn it all the way up to actually hear something.
Is there any setting I can change in DVD2avi and TMPEG to produce a better quality audio. Thanks!
Well, in TMPGEnc, there's a setting to max audio volume; I use it to gain consistency on tv episode compilations.
Hit 'Settings' at the bottom right-hand corner. In the 'Advanced' tab, you see a list of filters. The bottom one is 'Audio Effect'. If you check the box, it raises volume to the maximum. I haven't noticed any quality loss as a result of checking this, but then the audio has never been THAT much softer in my files. -
In DVD2AVI under Audio, choose Normalization. Check the box and drag the bar to 95%. I think this is loud enough without clipping the sound in very loud scenes.
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 20:58 -
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 11:25 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 08:02 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 01:19
