Hello everyone
I have a DVD that I converted so easily using TMPGEnc, the file is about 3.5GB MPEG-2 format.
How can I convert from MPEG-2 to MPEG-1?
I hope it can enable me to change the file size from 3.5GB to at least 1450MB.
The file can be adjusted by changing the bit rate. What do you want to do with a smaller file? I mean, you give up quality going from MPEG-2 to MPEG-1.
Hello. -
I need to put them in two or three CDs, I am willing to run them on a VCD player, not on computer.
Try looking in the Convert section at left. There are som many guides to do what you want, I am sure you can find something to put your movie on maybe even one VCD.
Hello. -
Other than the loss of non-supported interlacing, which is not present in progressive video, and of course the obvious disadvantage of re-encoding, there is no inherent quality difference between MPEG-1 and MPEG-2. There is also no good reason to make such a conversion.
You are probably thinking VCD and MPEG-1 are the same thing, which they emphatically are not.
What you really need to do is re-create the original conversion using a lower bitrate, probably in conjunction with a re-size to a lower resolution to avoid bitrate starvation. MPEG type is much less relevant than these other factors to filesize and quality.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 21:02 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 16th Dec 2008, 23:38
