I recorded from VHS to computer using WinTV PVR-250. I recorded in MPEG-2. OK so far. I can play the file fine in WinMed Player. No sync problems. I then use Sonic MyDvd (version 3 that came with DVD Burner) to author a DVD. Program says it will encode and burn. I proceed. All seems ok, except the final DVD's sound is out of sync with the video. The computer is a P4 2.53ghz RAM 512mb OS Win XP prof. DMA is enabled on the hard disks. Any idea's?
Follow these links, these are about the best ideas you will get on how to synch your audio with your video or get it as close as you can
https://www.videohelp.com/forum/userguides/140540.php
https://www.videohelp.com/forum/userguides/87443.php
The first link seems the most promising, as it explains it quite well, but I haven't personally tried it yet
The sencond link is for MAC users -
Reading your post again, I believe you may get better results by trying a directx filter in the tools section that locks the timing to your TV-In card, which from what I've read here and there may be the problem as the audio and video are slightly out of sync with each other
You need to somehow lock the audio and video timing together. I think having too large video dimensiosn can cause this, but as I haven't got a TV-In card (yet), then can't say for sure
There is somebody on here that knows a hell of a lot more, just can't remember there name -
I use WinTV PVR-PCI I had the same problem with Sonic MyDvd. . After capture everything played fine but after authoring with Sonic I got audio out of sync. Sonic sucks! With Ulead Video Studio works fine for me.
Video/sound out of sync and lagging on pc
By keaze in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2012, 22:09 -
Sound out of sync in ulead video studio..
By iames85 in forum AudioReplies: 5Last Post: 24th Apr 2011, 04:10 -
DVD Video/Sound out of sync!
By bprobinson in forum Authoring (DVD)Replies: 0Last Post: 23rd Feb 2010, 15:51 -
DIVX sound and video not in sync
By DarkPhoenix77 in forum MacReplies: 2Last Post: 27th Feb 2009, 11:48 -
Video and Sound are out of sync help!
By Rhoads in forum Authoring (DVD)Replies: 1Last Post: 14th May 2007, 20:11
