I upgraded my machine from 256 by adding 512MB. The memory is fine and applications like Sonic MyDVD seem to utlize the extra memory. But TMPGEnc seems to ignore a lot of physical memory and utlizes just a fraction of what is available.(During an MPEG2 DVD rendering session, the peak utilization was 289MB.
Is there a way to instruct TMPGEnc to grab the extra memory. I would assume the extra memory during rendering will speed up the rendering process(atleast to a certain extent)
I'd guess that's probably true. It you don't have a lot of CPU speed then grabbing extra memory isn't going to do anything usefulAlthough I suspect if TMPGEnc isn't using the extra memory, it doesn't need it.
CPU is the main usage, not RAM
Thanks for the info guys
I figure it is heavily cpu intensive and hence memory will not buy me much. -
With 1500mb of RAM, TMPG uses 450-500mb of RAM on my system. In the options under CPU, you can set TMPG to prefetch a certain amount of video to RAM. I have it set to 512.Originally Posted by sriramd
On your system, TMPG is using 289. You really don't have much RAM left. XP (with all eyecandy off), uses 130-160 by itself. 2KPro uses under 100 with nothing else running. -
Will the multi-threaded setting with prefetching of video on a single-CPU box have any positive effect on the performance(will the rendering session be quicker)
?- TBC in a SONY Hi8 player active when utilizing A/D pass through?
By DaveP56 in forum Capturing and VCRReplies: 12Last Post: 9th Feb 2011, 17:21 -
Help! Fed up of blue screen, physical memory dump problem.
By Varchasve in forum ComputerReplies: 10Last Post: 2nd Jul 2010, 10:38 -
Importing xml in FCP utilizing DH_Subtitle?
By leveleyed in forum SubtitleReplies: 1Last Post: 14th Mar 2010, 01:41 -
Utilizing nvidia purevideo hardware accel. for conversion?
By Vchat20 in forum Video ConversionReplies: 1Last Post: 13th May 2009, 19:09 -
Physical memory dump and now stuck on startup screen
By zanos in forum ComputerReplies: 8Last Post: 18th Dec 2007, 11:36
