  1. I am trying to convert a AVI movie to DVD format with mpeg audio in Tmpgenc with the Toolame audio tool plug in. I Keep getting "illegal mpeg audio stream" half way through the conversion. I have seperated the A/V with virtual Dub and saved the audio as a wave file first.
    can anyone help me? It Does not do that with the built in engine in Tmpgenc
    Thanks alot
    Apr 2002
    The State of Frustration
    What kind of audio does the AVI file contain, and have you scanned for bad frames yet?
    Hello.
  3. I believe its mpeg 2 layer 3 audio. No i haven't scanned for bad frames...would that do it?
    Dec 2002
    Costa Rica
    Are you using Toolame 02L?
    Try encoding with Toolame 02k instead.
