The program I captured with the PVR350 was going to be larger than 4G so it created a split file on the fat32 file system. I can switch the drive I am saving the captures on to NTFS but how can I use this capture? I can play it fine with the WinTV2000 but other software can't access the split part of the file so I can't do anything with the capture. I wanted to create a DVD of the program. Is there a solution?
I haven't tried TMPGEnc but other software can't open or even recognize the extra split part of the file as a valid mpg file. For example any player that can play mpg's will play the first file but not the second part which is a continuation of the first file. If I start playing the first file with the WinTV2000 software it seamlessly plays both files as one.
How to split a .TS video file based on time (not file size!) ?
By Michael REMY in forum EditingReplies: 4Last Post: 19th Sep 2020, 19:32 -
Batch "file creation from a text file, Placed into a created directory
By Muther in forum ProgrammingReplies: 5Last Post: 24th Sep 2015, 19:29 -
two questions on Hauppauge PVR350
By Ogilvy in forum Capturing and VCRReplies: 17Last Post: 2nd Jul 2010, 18:34 -
how to split mkv file and subtitle file to play on blu ray via hdd usb
By julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 12:28 -
Installing Problems, No file created
By jburkhardt in forum ffmpegX general discussionReplies: 8Last Post: 1st Nov 2008, 23:56
