I was wondering if anyone tried this? I tried to install my CD rom today, and it didnt show the easy install button, so I went and directly opened the Serup.exe, and it said I didnt have the avalavle components. I can get TV out to work ok, but I can't find a program to capture. I'm trying to hook it up through the Tuner, directly to my VCR, and the picture is all scrambled, And I can't install the software.
You have to download the latest drivers and MMC 7.1 from
http://support.ati.com/products/pc/rage128pro/win2k/rage128pro_win2k_drivers.html
These are windows 2000 drivers and mmc7.1
That should help, also running the "serup.exe" might not help, next time try the "Setup.exe"
I have a yamaha based sound card (Guillemot) and under XP it can't capture sound. You might run into the same problem, you might not.
Good Luck
Alfonso -
Hey, I did all that, But when I goto capture (Tried with a lot of progs, but I'll explain with V.dub) I went to video format, and all I can select is UYVY, Wont let me select any other format. And it wont let me capture like that. When I use other program, it says incompatible or something, and asks me to change it, But it's the onlyone. Real player says it's incompatible also... I've tried many programs.
VOB2MPG Pro / Win 7 Pro 64-bit Service Pack 1 Problem?
By Rich_A in forum SVCD2DVD & VOB2MPGReplies: 21Last Post: 2nd May 2011, 15:06 -
Corel VideoStudio Pro X3 and ATI TV Tuner Pro 650 Card Compatibility
By waldodiodio in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2010, 12:41 -
ATI AIW 128 720x480 mpeg captures have horizontal tearing
By cybertheque in forum Capturing and VCRReplies: 16Last Post: 17th Sep 2008, 20:53 -
Populating empty ATI VIP / AMC feature header on AIW Rage 128 Pro
By cybertheque in forum Capturing and VCRReplies: 3Last Post: 14th Sep 2008, 15:36 -
Didn't ATI All in Wonder 128 Pro have Mpeg capture?
By Ensign in forum Capturing and VCRReplies: 7Last Post: 7th Mar 2008, 09:13
