I captured some vhs material to my computer using an advc 100. It was a dv type 2 avi with uncompressed pcm. I then did some editing in Vegas 4.0 and rendered it as an avi again. I now want to convert the pcm to ac3. None of the guides seem to show how to convert pcm to ac3. I was wondering if the pcm is already in wav format or do I need to convert to a wav and then to ac3? After converting to ac3 I will be encoding the video to MPEG2 in TMPGEnc before authoring.
You are correct. PCM is WAV. In DVD circles you'll also see it called L/PCM. It's uncompressed audio. the same format on audio CDs, but sampled at 16 bits at 48Khz (compared to the 44KHz of CD audio).
It can also be AIFF
Transcode 7.1 DTS-Master Audio to 7.1 L-PCM (.wav/.aiff)
By nateo200 in forum Blu-ray RippingReplies: 10Last Post: 27th Apr 2012, 16:57 -
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2010, 00:35 -
Are Wav audio and PCM audio the same thing?
By yoda313 in forum AudioReplies: 2Last Post: 22nd Mar 2009, 16:46 -
capturing audio on PC to MP3 or WAV format, which software ?
By ktnwin in forum AudioReplies: 3Last Post: 2nd Nov 2007, 05:13 -
PCM to Wav
By woodie in forum AudioReplies: 2Last Post: 4th Jun 2007, 11:53
