Hi,
Anyone can guide me to convert .m2v files (SVCD) NTSC from 4:3 to 16:9 ratio??
Have tried on TMPEGenc, but i cant find the way to change the output ratio
Thanks in advance
Use the "clip frame" option to remove pixels from the top and bottom of your frame. I've found for a 1.85:1 ratio, remove 47 from top and botton, and for a 2.35:1 ratio, remove 60.
Thanks for your answer:
I'll prefer not to remove nothing from the actual resolution. I'm trying to "stretch" the movie, so a little deformation of the picture will occur, but that's intended; however not to remove any part of the movie is also intended.
Furthermore, I'd prefer a method through which no re-encoding, or minimal re-encoding is needed.
Any ideas?
How to convert FLV videos and resize them to convert them to AVI
By zikegi in forum Video ConversionReplies: 2Last Post: 18th Sep 2011, 00:06 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 06:44 -
To convert or not to convert a pal dvd
By nls8520 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 02:35
