Hi! I tried to burn myself some VCD just to try this feature. Everything works fine in the burning process. I tried WinON CD 3.8 and easy CD creator 5 platinum. When I play the VCD, I'm losing the top and botom of the film or video. They are out of the TV screen. I burn Photo CD with WinON CD 3.8 and i got the same problem. The pictures or films and menus are working fine.
I tried those VCD in my CD ROM player on my computer and everything is fine. So where is the problem? My Tv is a Big projection screen from Proscan. It is not a HDTV.
Thanks a lot.
I have the same problem. I don't know how to solve. It is very irritating. luckily, I can return it. I will ship this dvd player back to the store.
go in the settings menu on your dvd player... switch the tv aspect thing... that's what you may have to to
-tim p -
I have tried change the TV settings in the Panasonic DVD Player and also spoke to Tech Support from Panasonic. The problem didn't get resolve. There are three setting in the Video Aspect setting, 4:3 Pan&Scan(??), 4:3 Normal, 16:9. When the setting is 4:3 Normal, it should set the picture to 4:3 Normal in order to get the full picture from VCD Movies, but somehow this function for VCD does not work. For DVD, it was working fine. I suspecting this is a design flaw. Has anybody have this problem with the VCD Picture cut off? I returned my DVD player already.
I HAD this player, only returned it for another reason not worth mentioning, its a good player, my neighnor still has it and all VCDs I make for him are fine...be sure you stick to the right resolutions and bitrates for VCD...I did notice any change from 352x240(NTSC), if PAL (352x28
resulted in what you described...also, it is picky about staying at or below the standard 1150 bps video rate...max I have been able to do for this player was 1300 bps...however, that has no affect on what you are describing, just wanted to let you know hgtat as well.
Can I remove black bars (top and bottom) when backing up my dvd's?
By jammiev in forum DVD RippingReplies: 10Last Post: 17th Jan 2012, 14:19 -
By MGadAllah in forum Newbie / General discussionsReplies: 53Last Post: 26th Jun 2011, 01:44 -
Top & Bottom border
By burgin in forum Newbie / General discussionsReplies: 1Last Post: 9th Jun 2011, 19:31 -
Top and Bottom subtitles on dvd
By loster in forum SubtitleReplies: 3Last Post: 1st Aug 2010, 00:34 -
grey areas on top and bottom of ws dvd or vob file not on avi
By bobb52 in forum Video ConversionReplies: 3Last Post: 5th Feb 2009, 01:04
