hi i was making a tv ep dvd right and i used cce to convert them to the correct bitrate with high amount of passes to ensure best quality but when i used dvd architect to make my menuy and so on since it was the most user freindly. but when u put the video files u wantand when u finsih making the dvd menbu and layout and your ready to burn it automatically "renders" the dvd video wich i have already converted to the perfect size so itll fit on a dvd so theres no reason for that. Is there anwyay i can turn this autoconverting thing off cause i cant see how. thx in advance
Video
Click File, properties, check project video format (PAL or NTSC).
When converting a clip to mpeg2 ensure you select DVD-compliant output format. No matter how carefull you are in setting bitrate and resolution, an mpeg2 file is not necessarily DVD-compliant. Some DVD authoring tools may accept it, others not. For instance earlier versions of tmpgenc do not produce DVD-compliant mpg files; tmpgenc DVD author does not accept them even for reencoding.
Sound
If not AC3 or wav, it will be converted.
"Optimize DVD" window reports what is going to be done.
DVD Architect 5.0
By Mr. Robinson in forum Authoring (DVD)Replies: 1Last Post: 4th Nov 2009, 11:59 -
DVD Architect 3.0 problem
By Jvance in forum Authoring (DVD)Replies: 3Last Post: 1st Jan 2009, 18:58 -
DVD architect
By romanstopme in forum Newbie / General discussionsReplies: 4Last Post: 7th Apr 2008, 01:57 -
DVD Architect help
By monks19 in forum Authoring (DVD)Replies: 11Last Post: 23rd Aug 2007, 07:46 -
DVD architect
By Abiyad in forum EditingReplies: 1Last Post: 19th May 2007, 09:02
