Hi I'm a real newbie to dvd burning, I have some quick questions that I hope people will answer for me!?!?
I just got a Dell with a DVD+R/RW drive and DVD-ROM (2 Drives). I have a whole bunch of DVD-R's that I would like to backup.
1. Do I have to rip the DVD-R to my HD and then write it to DVD+R? . . . . . . . . .. . Or can I just do a Disc-to-Disc copy?
2. What is the best program to do my Disc-to-Disc copies? (I only do disc-to-disc copies with my DVD-R, Not regular DVD's)
I have Sonic Recordnow and My DVD LE that came with the computer. Would you recommend somthing else? I heard NERO was good!!!!
Please help me!?!? Thank You
If its already a rip then u shouldnt have to.U should be able to burn disc 2 disc. If u do have a problem then try dvd2one to retranscode it . Make sure that your dvdplayer"standalone" is compat with Nero. I have 2 players and one player plays with Nero and other plays with RecordNow. Ive never really had a problem burning movies except using "IMATION MEDIA " so try it what do have to lose.
https://www.videohelp.com/glossary#Transcoding
But most people here referring to transcoders mean "shrinking" programs, like DVDShrink. The above posts suggests DVD2One, another transcoder.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
Originally Posted by lost_boi
For copying DVD-R to DVD+R you can use any burning program such as Nero, RecordNow,....
Sometimes when a DVD-R is very full a problem can occur because the DVD+R holds 6MB less than a DVD-R.
You can solve this problem with DVD Decrypter:
1. Copying the movie as image to your hard drive: ISO read
2. Burning the image file to DVD+R: ISO write
You will get an error at the end of the burning process and miss the last 5 seconds of the movie but thats all.
Or you can always cut a couple of seconds out using DVD Shrink Start-End function.You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Thanks for everybodies help!!! But I just Burnt 7 DVD-R to DVD+R with NO PROBLEMS using Recordnow!!!!! Just put the discs in and hit copy!!! Easy as that!!!!! No Coasters yet!!!!!!!!!! (knock on wood)
Newbie Question - DVD+R versus DVD-R
By bobelk99 in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2011, 18:05 -
Trying to burn a dvd using dvd shrink and Nero 10, please help a newbie?
By KtuluAlly in forum DVD RippingReplies: 6Last Post: 30th Dec 2010, 13:33 -
translate yiddish dvd to english dvd-is this possible? From a newbie.
By humblejohn38 in forum Newbie / General discussionsReplies: 2Last Post: 17th Sep 2010, 05:20 -
DVD to storage drive, best media player for dvd playback- newbie questions
By omkls08 in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2009, 10:22 -
Newbie's DVD burner isn't recognizing DVDs as burnable (Both DVD+/-R)
By OhGodHelpMe in forum Newbie / General discussionsReplies: 9Last Post: 30th May 2007, 08:48
