Results 1 to 17 of 17
Originally Posted by ZippyP.
Dude,
Tmpgenc cannot handle AVI sound directly cause the AVI sound ould be a 2 channel or a AC3 or MP3 or whatever. So you need to extract the voice and then encode using Tmpegenc. Somehow some people start believeing that TmpegEnc can do everything. Give it a break and read here http://www.gkhull.pwp.blueyonder.co.uk/avitosvcdguide.htm -
The ac3 codec you need is the AC3 ACM Decompressor , click on the name of it there and it will take you to it.
When TMPGenc arrives you should change the priority if the Direct Show Multimedia Filter to a higher priority , if you don't you will probably get no sound. Have a look HERE to see how to do it.
When you are using TMPGenc and you select the source range , as you move the slider along you should see your audio in the form of a green line under the preview window if the line stays flat you will have no audio , and if the line alters then your output will have audio. -
Originally Posted by skullfullomagots
you are incorrect"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Originally Posted by BJ_M
I did the same thing with an AVI myself which had a 2channel stereo sound and 48000 Hz audio sampling rate. And my Directshow filter on TMpgEnc was high priority (priority 2) and I still did not get sound. I have been doing some reading around and then I came to know that TMpgEnc cannot handle AVI sound directly. Well I also very well know that it all depends upon the audio sample rate actually. So if the audio sample rate is 44100 Hz which is a standard VCD sample rate (WAV) then TMpgEnc willl handle it else it wont. And this is not the case with atleast 95% of AVI's I come across most having a 48000 Hz sampling rate. So, the guide's link that i have given will solve the problem so completely to practiacally annihilate any questions or doubts.Thus the purpose of my previously short reply.
Due regards -
I pesonally am a big fan of TMPGenc Plus. Now wether it's down to what codecs and filters I have on my PC . I can throw any file I have into it and I get sound . ( Just before I wrote this I loaded a file that had 48K 5 channel ac3 into it and the sound showed in the preview , If it shows in the preview then it outputs the sound)
I wouldn't do it that way , by choice I prefer to have ac3 on my DVDs so I would seperate the sound and use ac3 in the authoring stage.
But its just that TMPGenc WILL accept various types of audio. It may be the case that certain types of audio may have sync problems after encoding. But that wasn't the point. -
I say "normally", but actually I've come to the conclusion AVIs from the usual sourceare not at all worth the trouble. And the fun of playing with them has worn off. :P
Pull! Bang! Darn! -
there is no per se "avi Sound" it can be anything from mp2 to ac3
member since 1843 -
i used to be able to convert avi (even with AC3) to svcd or vcd directly using TMPGENC....however, after i reinstalled my XP, now i cam not getting sound with the avi files which has AC3...i've already moved DirectShow Multimedia File Reader to the top in the Enviromental Setting....can someone please help...thanks...
TMPGEnc Plus 2.521.58.169
Divx 5.11
VobSub 2.23
AC3Filter_1.01a_RC2
AC3ACM v0.7
(also tried ffdshow-20040520, same thing)
How do I change the aspect ratio in an MPEG file without........
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 13Last Post: 27th Oct 2011, 16:24 -
How do I change the speed of an MPEG movie file?
By mizpulp in forum EditingReplies: 17Last Post: 1st Oct 2011, 15:44 -
How to change AUTHOR, TITLE, ETC. of mov, avi, mpeg, wmv ??
By weezer76 in forum EditingReplies: 4Last Post: 28th Sep 2010, 16:02 -
Change DAR of MPEG-1?
By vonzippa in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2008, 20:17 -
Firmware to change MOD's to MPEG's
By Doctor2043 in forum Newbie / General discussionsReplies: 9Last Post: 18th Aug 2008, 04:09
