if a dvd re writer burns -r, +r, at 4x how fast is that? like in minutes
Results 1 to 17 of 17
hmm i did a firmware upgrade on my sony dru-500a drive... and it writes a dvd in 25 minutes... at 4x?? you got any ideas whats up with that... also you wouldnt happen to live in cumbria?
It kinda depends on how much data's on the cd...obviously burning 500mb is going to take a lot less time than burning 4gb
^ (useless response, I have nothing else to do)-Yar, matey!- -
I take it you set your burner up properly (DMA, master, separate channel etc).
Regards,
Rob -
erm not really... i just put it in... and used the same ide cable as i am with my cd-rewriter... my dvd rewriter is on the slave drive i think or secondary... but my cd-rewriter is on the master drive... how can i change this?
If you can't put it on a separate cable (but not RAID), but the DRU as master and the CD burner as slave - remember the little jumpers on the back of the drive?
Regards,
Rob -
I have a Pioneer DVR-106D and it only takes me on average to burn a full 4.38 ritek dvd-r 14mins 38secs to burn full disk...
25 minutes sounds to me like it's burning at 2.4x
Could be possible that it is reporting 4x but only burning at 2.4x
You could try different media and see if it burns faster. The current discs may not be liked by the burner and will only burn at 2.4x -
I had the same problem could not write at 4x even though it said it was ..The problem was the media .. i have fornd that Optodisc gold 4x and fujifilm 4x burn in 14 min. others i have tried have not
Moviefreak,
A lot of replies to other posts have explained that 4.7 gig is equivalent to a 160 gig hard drive's advertising.
4.7 billion bytes. They play silly numbers games, ussing 1 billion as a "gigabyte" whereas 1073741824 is an actual binary gigabyte X 4.38 comes out to approx 4.7 BILLION bytes.
My 160 "gigabyte" HDD is only 152 gigs on one machine. Funny, though, the one on the other machine reads 163 gigs.
I don't know whether they design a batch as 160 and format them and some can go higher than others, and still get shipped in the same batch.
Same, I guess,as the WDs they were selling as X gig, 20 gigs free, actual X+20. Maybe it all depends on what they need to make that week, can be formatted as 60 gig or 160gig, same device..
This might be entirely inappropriate in this post.
Sorry. -
please can someone explain why you shouldnt put a dvd burner on raid,
actually what is raid
Thanks -
Check this site for a definition of RAID: http://searchstorage.techtarget.com/sDefinition/0,,sid5_gci214332,00.htmlOriginally Posted by maveric4001
Because RAID involves duplication of data on multiple disks, using a DVD burner would make it very complicated, to say the least. -
Hi Ebenton,
Thanks for the link (interesting)
But can you help me clarify that if you install an IDE 133 controller card it wont be raid, and that raid is a totally different kind of card. That being the case could I also assume that if I put an Ide 133 controller card in my machine that it will work with opticals, or are there specific cards for that job to.
I would appreciate a list of what you know works well if DVD backup (ie ripping, burning) is the main priority
Thanks M8 -
Blank DVD-R 4,489MB 4,706,074,624 bytes or 4.383GB
Blank DVD+R 4,483MB 4,700,372,992 bytes or 4.377GB
8X DVD+R burntime 9mins
4X DVD+R burntime 14mins
4X DVD-R burntime 16mins
2.4X DVD+R burntime 22mins
2X DVD-R burntime 31mins
1X DVD-R burntime 61mins
Audio track speeds up going from AVI to DVD
By jenna1 in forum ffmpegX general discussionReplies: 2Last Post: 19th Oct 2011, 16:22 -
DVD burner read/write speeds
By ecc in forum Authoring (DVD)Replies: 9Last Post: 13th Apr 2008, 06:49 -
DVD Decrypter / DVD Fab - Extremely slow ripping speeds in Vista
By awp in forum DVD RippingReplies: 5Last Post: 19th Dec 2007, 14:11 -
Burning speeds and DVD Decrypter...
By Nilfennasion in forum Newbie / General discussionsReplies: 6Last Post: 20th May 2007, 05:32 -
DVD Writing
By netpicker9 in forum Authoring (DVD)Replies: 5Last Post: 16th May 2007, 00:16
