Hello. I've searched through this great site, but I haven't found the solution to my problem. Perhaps you can help me.
I have a bunch of mpegs encoded for XSVCD that I want to burn using Nero. I set Nero for SVCD. I uncheck the standard compliancy box and start the burning without letting Nero encode my files. The disc looks great when played in WinDVD, but in my regular DVD-player (JVC XS N5SL) the sound is wobbly and the speed is dropping every now and then.
Any help appreciated... Thank you. /Jim
you haven't really given much to go on but at a guess i would say your standalone player is struggling to play your xsvcd
Well, according to the compability list on this site my standalone DVD-player should be able to play XSVCD. It can handle the aspect ratio (as I understand it's wider than SVCD), but the speed slows down from time to time and there's a ringing sound every time this happens. Do I have to re-encode it someway before burning it with Nero? I can convert it to SVCD, but then I won't get the advantage of the higher image resolution that XSVCD gives.
Any help appreciated, thanks for you effort...
/Jim -
exactly what are the specs of your xsvcd, every detail
"X"svcd simply means an mpeg2 that is outside of the SVCD specifications for either bitrate or resolution, there is no Xsvcd standard. It does not necessarily mean that your DVD player will handle any Xsvcd, especially if your mpeg is way out of the standard. The closer to the standard, the more likely that your player will handle it. You need to experiment a bit, starting with higher bitrates then changing resolutions to find out what your player can do. It sounds to me like you've created a disk that your player just will not play.Originally Posted by qe"Art is making something out of nothing and selling it." - Frank Zappa
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 20:23 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 22:09 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 12:10 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 06:06
