  1. Hi, I am using TMPGEnc + v2.59.47.155 (to b exact) and it almost always crashes at 99%. I have read posts about it crashing at various stages in the conversion but mine only ever crashes at the same point. it used to be ok till i started using the "batch encode" and thats when the prob started. I then stopped using batch encodes and went back to single but its crashing just the same, i have also tried reinstalling the prog, but to no avail. hope someone can help me ...thx in advance
    :) "Janey is m' Sunshine" :)
  2. I have the same problem sometimes, but missing a few frames of credits isn't a worry to me. Can you still use the created file after TMPGEnc crashes out??
    Also try this,
    1elete "Currentcfg.tpr" and "TMPGEnc.ini" held within the instalation directory. (they will be created again when you next open)
    2:Open TMPGEnc & cancel wizard.
    3:Load in the unlock template.
    4:Open files and try encoding again.
    Hope this helps......
    "I haven't committed a crime. I just failed to comply with the law."
